Is there a way to incoperate Fruity loops or Ableton live with virtual DJ? I saw that Fruity loops does not work as a VST plugin But, has anyone actually been able to use thes programs alongside with VDJ?
geposted Mon 12 Nov 07 @ 11:02 pm
U mean do the looping thingy n ur own tunes??.. Yes u can but u need to have at least 2 com running n both connected to ur mixer so example if one channel from vdj bpm is 130 etc, the same should be apply at fruity loops.. plus minus.. n u have to fine pitch/set it by ear:) I dun think it can be sync automatically both the different software.
geposted Tue 13 Nov 07 @ 7:42 am
virtual dj unfortunately doesnt support rewire so they cant be automaticaly synced to run them on the same pc would require alot of resources
geposted Thu 15 Nov 07 @ 1:22 am
