i just download the demo 1 week ago and im loving it more than torq
i did a rock mix with vdj its on my myspace with just using my mouse
as fun as that was i wanted to know what kind of time codes does vdj take
does it use 2 to 4 cpu core's
i saw i can open 2 at the same time
if i have 2 sound cards can i use 1 vdj with asio and the other with mme
can i run this along side mixvibes i like this and mixvibes dvs
geposted Tue 13 Nov 07 @ 7:23 am
ps im realy thing about selling torq and buying numark cue aka vdj
and run it with my rme rpm sound card
geposted Tue 13 Nov 07 @ 7:02 pm
virtual dj supports , virtual dj timecodes , numark vv timecodes , and soon sterato vinyls thanks to the work of a kind user who is writing a plugin for them
it will utilise 2 cores but you can just use the one if this what you have
it depends for what you intend to use the cards for?
mixvibes uses alot of resources so does vdj so you would need a very fast machine
geposted Tue 13 Nov 07 @ 7:05 pm
for now i have a q6600 quad core clocked in at 3 ghz
and 8 gb of ram at 950 mhz with 2 raptors 10,000 rpm hard drives sone to be in raid
i have someone that over clocks my set ups for me
i dont use a laptop i use a rack mount pc :)
do u think thats the type of horse power i need to run this ?
geposted Wed 14 Nov 07 @ 1:30 am
Um I would say that the specs you listed will run great with VDJ overkill for the average user but will work, what are your video card specs??
geposted Wed 14 Nov 07 @ 2:44 am
