Hi will there be a multinstance skin for virtualdj 5?I really need one...thanks
geposted Thu 15 Nov 07 @ 5:21 am
hola amigos kisiera bajara alguno de sus skins pero no me da chance, a ver si alguien por ahi se apiada y pasa alguno.
se agradece el aporte saludos a toda la comunidad.
geposted Fri 16 Nov 07 @ 1:31 am
https://virtualdj.com/addons/skin.html?id=3152
@ dj oyuky
Please Speak in English in the general forum or use the Spanish forum.
@ dj oyuky
geposted Fri 16 Nov 07 @ 8:28 am
HI,
Was wondering if there is a V MIX 5.3 Multi instance screen with a 1280 x 800 Resolution. The only one I was able to find was V MIX 5.3 SIngle Instance skin 1280 x 800.
I tried the V MIX 5.2 Multi Instance Skin 1280 x 1024 , but the second set of decks doesnt seem to fit into the screen. The maximum resolution I can get is 1280 x 800.
This is a great skin, and hopefully a Multi instance with 1280 x 800 res. is available.
geposted Mon 03 Dec 07 @ 2:53 am
