Hello! I have tried the Hercules DJ Console mk2 with Virtual DJ 4.3 for Mac together with at friend that has a Mac. It worked properly. The problem was when I wanted to try with timecoded vinyls. As I changed the settings to two timecoded vinyls, the settings for the soundcard switched automatically to Numark's soundcard. I have also tried the same thing on my own PC, and it worked just fine. As you may understand my version of dj console mk2 was from the beginning PC. I've heard that it doesent matter.
The question is if version 4.3 support timecode vinyls for hercules dj console? Will it be available on version 5.0?
//Nils from Sweden
//Nils from Sweden
geposted Fri 16 Nov 07 @ 1:44 pm
no, 4.3 only support NVV card when timecoding.. But 5 have changed n it currently available to pro user only. If so..tell ur fren to test the public beta..
geposted Fri 16 Nov 07 @ 3:22 pm
