Hi!
Just got my M-Audio Xponent (don't like Torq at all !) Work's ok with 5.0r5, BUT the cue button is not mapped correct, after a few secons playing the cue button don't "cue" the song as it should, it just set a new cue point on the "fly" and don't even stop playback. Strange is that cue button works the first seconds on a song... Try...
Next, because I cant no longer change the MIDI mapping for Xponent, I like to se an option so I get crossfade to only affect the video, not the sound.
Yes, I know I can use General MIDI and map Xponent my self, but then I don't get LED on buttons to work in sync with VDJ.
Please fix this!
Thanks.
Please fix this!
Thanks.
geposted Tue 20 Nov 07 @ 10:14 am
PM replied to :)
I'll implement the option for the crossfader and have a look at the CUE functionality for you. I need to change it anyway to implement stutter, so it was already on my to-do list ;)
geposted Tue 20 Nov 07 @ 11:44 am
Crossfader for only video? NO problem!
Is already possible with any controller and without any modify in the mapper.
Go in CONFIG -> Options and select Crossfader "Disabled" then go in Video option and select Linked Crossfader ;)
geposted Thu 22 Nov 07 @ 4:34 pm
