Dear all,
Is there any way to use timecoded vinyl with a maya 44 usb sound card in vdj 5 beta 3 on a mac. I looked at another article that says you must use the aggregate device but that doesn't work. Do the old tcv not work with version 5? I can't get timecode signal but I am able to play music from the maya using tcv mode with the timecode bypassed. I thought that the new version would work but I guess not. Maybe I could get some help from the teamers.
Thanks
Thanks
geposted Thu 22 Nov 07 @ 6:21 am
hi , the agrigate device trick should work ,
to clarify all previous tcv will work
have you tried applying the auto config and what latency have you added in performances?
geposted Thu 22 Nov 07 @ 2:01 pm
I was not able to get any signal ever. I tried the agregate device and that didn't work either. I have not messed with the latency setting but maybe I should.
Thanks
Thanks
geposted Fri 23 Nov 07 @ 6:55 am
Well I booted up my computer today and tried the aggregate device thing and it worked. Thanks a lot.
geposted Fri 23 Nov 07 @ 8:35 am
happy days :)
geposted Fri 23 Nov 07 @ 9:34 pm
