Hi. I have beta3 installed on my mac. I want to dj with it asap but im not sure whether i should have v.5 beta3 or v4.3 installed so as to be assured that it doesnt crash during a set?
Thanks, Ben
Thanks, Ben
geposted Sun 25 Nov 07 @ 8:35 pm
beta 3 generaly wont crash unless you use the dac 3 , or the hd400
geposted Sun 25 Nov 07 @ 9:40 pm
is it more reliable in a club situation than 4.3? That might seem obvious but i want to make sure im not going to crash, im putting a lot of trust into this working and not messing up on me. . .
Thanks, Ben
Thanks, Ben
geposted Tue 27 Nov 07 @ 6:44 pm
in my opinion yes , why not give it a spin
if you dont like it you can go back to V4 easily by just installing it over it
geposted Tue 27 Nov 07 @ 10:30 pm
I can see that v.5 looks better to use but im just very scared of it crashing during a set. I really am finding it hard to believe in a computer to hold everything together. Its a new macbook pro, with dual 2.4ghz and 4gb ram so it should be ok?
Thanks, Ben
Thanks, Ben
geposted Wed 28 Nov 07 @ 1:20 am
