I love the VCI, eventhough it doesn't have a soundcard, but the one problem as I hook it up to different mixers is that I can't use the Crossfader on the VCI because it cancels out Headphone cueing on either channel on the mixer(i.e., Allen Heath, Nu04, Numark). I am using a Maya44 usb with the latest updates and the card works fine. It took me months to figure out that I had to Disengage the headphones in Config.
I would prefer to use the entire VCI for cueing AND mixing as opposed to using the actual mixers' crossfader. Any suggestions? Thank you.
geposted Mon 03 Dec 07 @ 1:28 pm
