Forum: Old versions
Topic: Virtual DJ Vers.5 with Windows Vista and Numark DJIO...
Hi there,
i go crazy, cause Virtaul DJ Vers. 5 doesn´t work well on my new laptop (dual core, 2Gb, etc...High-End machine). I´ve running Windows Vista and did nearly everything to install a High-End Performance like shut down the index-funktion, close all not used stuff like Wlan, etc...and on Virtual DJ i installed the lowest latency the fastet performance, etc...but still Virtual DJ is not running well. You can see (the beatline interrups a bit) and hear that the Tracks are interrupting a bit, every few beats a beat sounds a bit "swallowed". So what is wrong? A Vista Problem? I´ve installed the newst drivers of the Numark soundcard as well...Someone please help me....
geposted Thu 06 Dec 07 @ 5:20 am
Hi are you using your system with pro cd players? If so make sure you download and burn some cds using the -13db timecode signal. I had the same kind of probelm as you and it tuned out thats all it was.
If not that sorry but it was worth a try!
Please do not promote giving away free CD's on our forums. Depending on what's on these CD's, it may be illegal (E.g: Copyrighted music.) Even if it's all your own work, then advertising is not permitted on the VirtualDJ forums - Please see: https://virtualdj.com/wiki/Forum%20Rules.html
Also, we do not recommend posting your personal contact details on a public Internet forum. We have raised the level of your post to Limited Edition users and above to help protect your details from being obtained by spammers, fraudsters, etc.
Please also don't bump old topics. This topic is nearly 4 years old and your message is not related to the original topic in any way (It has nothing to do with using VirtualDJ v5 (Now an old version) on Vista with Numark DJIO.)
[Old topic closed]
