Hola,
I have the latest version f virtual dj installed!
But when I vieuw most of my wma files, it does not show the artist name but only the title...
The wma file has all the information, but it is not proprly read in virtal dj!
Is there a fix for this? Please help!
Greatings Jay!
Greatings Jay!
geposted Sun 09 Dec 07 @ 1:27 pm
VDJ does NOT support WMA file tags and according to the VDJ Tech Support team, has NO plans of supporting them. VDJ can play WMA easily, but the file tags are not supported.
I have found that you can rename the files for Rhapsody. You have to rename them in "Artist - Track" format with the hyphen and the spaces for VDJ to read it properly by name. I use a program called TagandRename.
You can select a whole truckload of files and it will read the WMA tags and rename all of the selected files in the way you want. The renaming doesn't affect the DRM tag on the file (or the file tag at all for that matter). I don't know that this would work for any other service, but Rhapsody's DRM works this way so far. As a matter of fact, you can download the same song several times and it will create a different name every time. It will add a 1, 2, 3, etc. to the file name.
Napster is integrated into VDJ, so it doesn't seems to be an issue.
I hope this helps many of us other WMA DJ's.
Chris Kelley
Chris Kelley
geposted Tue 30 Dec 08 @ 5:27 pm
