hi guys ...
i just want 2 ask if i can connect virtual dj to djm-800 on my laptop ???
i only have the laptop ( HP) and the mixer ... what equiment & cables do i need 2 buy??
thnx :)
thnx :)
geposted Tue 11 Dec 07 @ 2:47 pm
you require a midi to usb cable/dongle
geposted Tue 11 Dec 07 @ 3:14 pm
thats it ??? i dont have 2 buy 2 sound cards??
geposted Tue 11 Dec 07 @ 3:32 pm
you have to buy one soundcard since your computer have a soundcard..
Then you have to get a jack -> RCA cable and connect it from the two soundcards to 2 different channels of the mixer..
go to the settings of vdj assign to play each deck from different sound card... and here it is! Voila!
you can mix the 2 songs through djm800
Just that simple!
Just that simple!
geposted Tue 11 Dec 07 @ 3:48 pm
how to assign to play each deck from different sound card?
dj homa if i have 1 soundcard is maya44 all rca connect to djm800 and my cdj and usb of maya44 connect to my laptop is it correct?
and i have to connect midi out to my laptop one more lead right?
thank you
thank you
geposted Sun 13 Jan 08 @ 8:51 am
I ended up saying screw it and not mess with it and just went and got Serato/Virtual Vinyl
2 cdj1000's into serato/vv box which is usb to computer, out of that box into djm800 out of djm800 to efx-1000 out to speakers
i gave it a good long though and unless im using like ableton with it, i really dont see a point of having my DJM-800 midi attached to the computer... all i can see is it causing random glitches to a perfect mixer... if there were extra midi assignable buttons on it that would be another thing.. i wanna pick up a midi touch pad for quick loop buttons and what not
geposted Sun 13 Jan 08 @ 12:57 pm
can anyone reply me???? thank you very much
geposted Sun 13 Jan 08 @ 5:48 pm
yes i believe so you need the midi wires there some dude on youtube with it he had some issues but everything worked out i use my djm600 work excellenmt with my efx500 and mk2 my next move are some cdj
geposted Thu 17 Jan 08 @ 11:30 pm
