I bought a few songs from Itunes and they are formatted as M4P and not MP4. Is there a codec where I can try and solve this proplem.
Thanks
Thanks
geposted Tue 11 Dec 07 @ 5:11 pm
try converting them within itunes itself. I use itunes to rip and convert my music.
geposted Tue 11 Dec 07 @ 5:20 pm
AFAIK, M4P and MP4 are the same thing, they both use Apple's AAC codec. You can just define the extension in the options > codecs tab and just set the codec to the same thing as MP4....
geposted Tue 11 Dec 07 @ 8:49 pm
Bought from iTunes = has DRM. Except for the EMI stuff I guess but you didn't specify.
Virtual DJ won't be able to play the files straight away (content is encoded and Apple hasn't licensed the cedec to *anyone*). Also, iTunes won't let you convert the 'protected AAC' files with it's inbuilt ripping tool :(
The workaround is to burn to CD then import from the CD in your preferred format. No software (currently) available to strip the DRM. Some programs claim to do it but they are just performing the above workaround on the HD: creating a disk image then ripping from the 'disk'.
geposted Sun 16 Dec 07 @ 3:52 am
Another workaround which is irritating but works better than using a cd is recording the song with audacity, then saving it as a mp3
geposted Sat 29 Dec 07 @ 10:56 pm
You can also use this program
unfortunitly it is a 14 day trial :(
http://www.wma-mp3.com/protected-music-converter.html
geposted Sun 30 Dec 07 @ 8:11 pm
I just found this http://www.protected-music-converter.com/, it's a 30-days vision, you can follow the guide on that site.
geposted Tue 22 Sep 09 @ 12:37 am
