Worked fine yesterday
today once i pass the middle of the crossfader bar with the console ( either with my PC mouse ) i don't hear anymore the second song ( lets say the B ) its move on the A one ( even if i just passed te middle and im still near it ) looks like its blocked or so , how fix that ?
geposted Wed 12 Dec 07 @ 8:16 am
are you using console edition?
is it under 2 years old if so it is covered by a manufacturers warrenty
contact hercules support
geposted Wed 12 Dec 07 @ 8:41 am
It sounds like your crossfader curve is set to "cut." You probably want full or smooth. You should find it in the "config" menu.
geposted Fri 14 Dec 07 @ 3:26 am
