My computers microphone won't work with my Virtual Dj v5rev6. I don't have any other hardware running with virtual dj either. Why can't I use my pc microphone within the realms of virtual dj without any other hardware?
geposted Tue 18 Dec 07 @ 12:59 pm
AFAIK, there is no mic input interface on vdj? can someone clarify this for certain?
geposted Tue 18 Dec 07 @ 10:05 pm
Depends on what your trying to use the mic for. Example..you can record from a mic using VDJ...as long as you have it set up properly. Also some skins have mic volume controls....some don't. Its all subjective...
geposted Tue 18 Dec 07 @ 10:30 pm
hello, can someone tell me what settings shall I do to connect the mic of the laptop to the Vdj. I connected a mic with the laptop, but i cannot find the settings on the display. I appreciate all support pls
geposted Thu 14 Jan 10 @ 12:04 pm
