Hi guys.....
Is it possible to change the pitch on a deck without dragging the bar up and down? (I dont find it very accurate) I was hoping that maybe it's possible to use teh + and - keys but I dont think this is the case?
Thanks.
Thanks.
geposted Fri 21 Dec 07 @ 1:13 pm
you can make a keyboard shortcut to change this
go to options > shortcuts
and choose the actions you want
geposted Fri 21 Dec 07 @ 3:22 pm
more specifically, find the pitch option in the shortcut list. add two with different values.
what i map are my keyboard left, right, up & down arrow keys:
left: nudge: +128
right: nudge: -128
up: pitch: +1
down: pitch: -1
left: nudge: +128
right: nudge: -128
up: pitch: +1
down: pitch: -1
geposted Fri 21 Dec 07 @ 10:08 pm
