Hey all,
I've been having some technical issues with using a mic while broadcasting. I'm using two different soundcards, one being my realtek onboard and another being my soundblaster audigy. I have my speakers running from my onboard and my mic on my onboard and my headphones on the soundblaster. I'm trying to get a microphone configuration to work using DJ CEL's Microphone Control v2.3.0.1, but whenever I go to select a new wave device, i get mixer.cpp errors. The microphone setup works fine, but I cannot select any wave devices.
Can anyone offer an either simpler plugin or a solution to this madness? ;)
--DJG
--DJG
geposted Sat 22 Dec 07 @ 1:26 pm
what version of virtual dj do you use?
please add your serial so you can get the latest updates for vdj and that plugin
you will find that will greatly increase performance
hope to see you with us soon
geposted Sat 22 Dec 07 @ 1:54 pm
