ok quick question is the timecode for Vinyl and CD the same line of code?
the reason i ask is i want to have a custom vinyl cut from a local cutter.
really cool lookin plate i got made all ready to be cut. ;-)
but i need to know 3 things
1. can i use the TCCD mp3 Consumer Grade Sound Level thats 12min in length and trim it to 8min.
*** if not where can i obtain the Vinyl timecode audio for my personal custom TCV. it would mean alot to me ;-)
2. can the timecode be cut in mono? "33RPM" "both left and right channels will be the same"
*** if not TY, no biggie i can cut stereo as well
3. Can i cut this record for my personal use, *** Not for Resale, for actual use***
the reason i ask is the matirial i have ready to cut is very expensive and very longlasting for hardcore scratching,
lol you could probably run heavy needled and only kill the needle lol ;-)
and to answer a future question for future readers http://www.customrecords.com is where i'm having it cut.
Thank you for your time, merry Xmas. and happy holidays
geposted Sun 23 Dec 07 @ 4:30 pm
1) yes you can trim it
2) It can NOT be mono, no.. Scratch wont work then, and other things might be wonky too
3) you can do what you want, even sell it if you like...
geposted Wed 26 Dec 07 @ 8:30 pm
Sweet :D
cuttin it in stereo tonight ;-)
naw wont sell it, there like aluminum based with vinyl coating, very solid, i'll beat the hell outta it n update this post with "success or fail results" for future reference in case a search option is used lol ;-)
i'm willing to risk a dubplate for this cause.
Thank you Norway.
and happy holidays :-)
Thank you Norway.
geposted Wed 26 Dec 07 @ 8:53 pm
Best of luck ;) sounds like some damn cool vinyls
geposted Wed 26 Dec 07 @ 8:56 pm
they have vinyls that offer longer cuts though.. 12 and 16 mins
http://www.customrecords.com/33rpm_LP_album_vinyl_phonograph_records.html
But guess u know that
geposted Wed 26 Dec 07 @ 8:59 pm
yep yep it's a local cutter to me ;-)
Thanks again
Thanks again
geposted Wed 26 Dec 07 @ 9:25 pm
