I am kind of new at this, so please bear with me. What software would you guys recommend to convert audio cd's to mp3 format? Thanks in advance for your help.
Jean
Jean
geposted Mon 14 Jul 03 @ 6:58 pm
There are many! Some freeware, some not. CD-ex, audio catalyst, music match, real player, even windows media player has an mp3 converter available....
geposted Mon 14 Jul 03 @ 7:08 pm
Or simply use the software !
If you have downloaded the lame codec for the record pannel (search this forum for 'record in mp3') you can insert your CD, browse to the drive location select a track and right click --> choose copy to and virtual Dj will automaticcaly rip the track to mp3 format.
To rip directly in MP3 you just have to select mp3 format with the dll file on the record pannel
geposted Tue 15 Jul 03 @ 1:42 am
use CDEX .. (do a google search).
Best program for ripping files. make sure to rip at LEAST 192 kbps.
geposted Tue 15 Jul 03 @ 3:00 am
I have found a program that works allot better than CDEX it is call dbpoweramp. It really does a great job and does it fast. I have found myself actually using it right on the job along with the ATOMIXMP# running and I had absolutley no problem with speed or quality. But, yes please use 192kbps.
http://www.dbpoweramp.com/
DJ Troyka
DJ Troyka
geposted Tue 15 Jul 03 @ 3:15 am
like dj trip_likeido i say do a google search.....but for rightclickmp3.....it is by far the simplest wav to mp3 to wav converter out there...you can set your kbps from 32 (yuk) right up to 320 kbps...96 is F.M. quality...if you are only going to mix stuff for computer work 96 is fine...160 up to 192 would be for d.j. work in clubs etc.....anything above 224 and you are getting into studio quality....this program does it all for you and its FREEWARE
geposted Tue 15 Jul 03 @ 10:47 am
i think this is the one for people who are in to make "best quality mp3":http://www.exactaudiocopy.de/
geposted Tue 15 Jul 03 @ 3:38 pm
Thanks all for your feedback.
geposted Tue 15 Jul 03 @ 11:05 pm
I use MusicMatch Plus for creating MP3s.
Great quality and no problems :-)
geposted Tue 15 Jul 03 @ 11:07 pm
