I apologize in advance if the answer to this question is right under my nose, but I searched the forums and could not come up with an answer.
Is there a way to do headphone split cueing using the internal mixer in VDJ? For those who don't know, split-cue is when the left deck (or the left side of the crossfader) comes out the left channel of the headphones and vise-versa.
I know that this is an option on most professional mixers, but I am personally too attached to my Total Control to switch to an external mixer.
Thanks-
Thanks-
geposted Wed 26 Dec 07 @ 8:04 pm
Not currently,as far as I know, but could be added as new feature, should even...
right now, you can crossfade prelisten (cue) with a function called headphone_crossfader, where you can choose what deck to hear, or the value of blend between them (some skins have this built in, or you can make a keyboard shortcut to the function).
Vdj also have a headphone_mix that works similar, where you can control the amount of "bleed" form the other deck to be heard in your headset, from nothing to a complete overlap
geposted Wed 26 Dec 07 @ 8:10 pm
Nothing about the Split Cue function yet ?
geposted Tue 11 Jan 11 @ 10:20 pm
Please don't bump a post from 2007, especially when you've just bumped one on the same topic already in wishes and new features.
geposted Tue 11 Jan 11 @ 10:43 pm
