I'm using vDJ5 rev.6 for some time but only today wanted to do some mix. Before I used one multichannel (5.1) sound card (Creative SB audigy) to use rear out's as Headpohone out! But today in my head was born an idea that I have integrated sound card, too and VDJ allow to use 1 SC as main out and second as Headphones out. So i installed onboard card audio driver and oll looks ok! Opened virtual dj, in preferences put the configuratio (SB Audigy - Main, Integrated Realtek AC97 - Headphones). All works... Started to creat mix and ... Crash The sound stucks... Recovered, but it broked my mix. Tried some times but it crashes all the time! Sometimes after 3 songs, sometimes after 1 but crashes every time... Restarted PC but no effects. HElp please! Maybe anyone had seen this problem!
geposted Thu 27 Dec 07 @ 11:36 am
System specs please?
Try running one card at a time, to see if the crash follows on card around.
How are you setting your sound config up? 4.1 + 1 maybe?
geposted Thu 27 Dec 07 @ 7:45 pm
i have a realtek 5.1 card on my kickass alienware laptop... it bites for vdj. in theory you'd think that an integrated chip should work really well... but it doesnt. the architecture is only made for listening and movies, and not for low latency applications. go for an external soundcard that supports asio
geposted Thu 27 Dec 07 @ 11:44 pm
Wondering if VDJ uses the same latency for both soundcards, thus the Onboard would hate low latency, while the SB would be happy with it. Perhaps try poping the latency up a notch.
geposted Fri 28 Dec 07 @ 2:41 am
Nop! I have the same problem and raising the latency even to great amounts won't fix the problem ... Also installing the latest ASIO drivers and enabling them in sound setup didn't work ... Virtual DJ just REFUSES to work with 2 sound cards (at least with the 2 I am using AC '97 AUDIO on board and AUDIGY SB like the guy above).
That sucks in my opinion ... OK I bought the Audigy SB to be able to mix "non-blindly" and now I have to actually buy a third usb-sound card to do my job? Ok it might not be so expensive I mean the card cost around 20euros or so ... BUT still it's money... I'm really frustrated about this .... If there is another faster solution I'm willing to hear it!
Thanks in advance
Thanks in advance
geposted Wed 26 Nov 08 @ 7:08 pm
The faster solution is to at least buy gear (your soundcard) that is at least close to a PRO level of gear. A 20euro card will get you 20euros of performance. The same difference between Gemini gear and Denon/Pioneer gear. Gemini is your 20euro gear - and yeah the Denon/Pioneer might be more expensive but you are getting the quality. Buy the MAYA44 USB and you will be good to go.
geposted Thu 27 Nov 08 @ 12:20 am
All will still come back to your budget. What you bought is what you get.
The higher the price the better the quality and the better your software will perform obviously.
Oww by the way, VDJ PRO is only $299 (243.87 €), hope you won't forget it.
geposted Thu 27 Nov 08 @ 4:23 am
But my main problem is not the sound quality ... It's just the facts that I can't mix at all cz the programe crashes! If I could play a song to the speakers and simultaneusly preview the next on my headphones I wouldn't care about the quality at all! But I can't even do that ... that's tha case that cracks my nerves! :)
geposted Fri 28 Nov 08 @ 1:14 pm
Hey everyone
I have:
SB XFi Xtream Audio (PCI)
Realtek HD Audio (onboard)
AMD Athlon 2x64 6000+
Gigabyte GA-m57sli-s4 MoBo
GF8800GT 512M
I am having a possibly similar problem, i can mix a few songs then one of 2 things will happen:
1 my main output (SB XFi PCI) will crap out and one of the tracks will be overdriven, sometimes only left or right (not verry friendly to my speakers) if i close VDJ then reopen problem is gone for a little while.
2 crashgard is activated and closes the program, no speaker mashing noise but still just as anoying
these problems usualy ocur when i am adjusting fader/levles/efects but i dont know if that is causing the issue or just a coincidence.
I also have an IBM P4 and using a similar setup this works fine
P42.8
SB Audigy2 & onboard
I will try some difernt configs and get back...
I have:
GF8800GT 512M
P42.8
geposted Sat 26 Dec 09 @ 11:06 pm
It's a known issue with creative drivers when view have to deal with an onboard sound card.
geposted Sun 27 Dec 09 @ 5:56 am
Sorry to dig this issue, but my 2 cents...
I used to be a Creative Audigy soundcard owner, and after several crashes and troubles, I found a way to work with it and a Soundmax on-board soundcard, both in the same system with Windows XP SP3.
Just install ONLY THE DRIVERS of your soundcards, dont install players, managers and every other software. Simply put your installation CD, dont run it, and run the windows hardware manager to install the soundcards, dont forget to set the checkbox to only install drivers.
You will configure both soundcards by Windows sound devices manager, just choose the default device before manage it.
Creative soundcards are provided with a dozen of crap softwares, and I believe this was the cause.
After this, I never had problems with VirtualDJ and my 2 cards anymore.
geposted Tue 03 Aug 10 @ 12:22 pm
i cant use my sound card and my numark total control together it allways crashes im the sound im usin is PD511 2.1 usb sound adapter how can i get around this problem could sumone help me out by emailing me -------------------------- thank you
Sorry emails by Non-Licensed Users is not permitted - Moderator
geposted Sun 05 Sep 10 @ 6:50 pm
my virtaul dj wont open.. it says a fatal crash a had been accoured i click the recover problem but nothing happens.. pls help me im using a vestax typoon.. its comes with v dj LE... PLS HELP ME...
geposted Sat 26 Mar 11 @ 1:37 am
nevermind - disregard - i didnt notice the age of the posts here
geposted Sat 26 Mar 11 @ 4:44 am
Please open your own new post on this subject rather than bumping and old topic from last year.
geposted Sat 26 Mar 11 @ 2:40 pm
