Is there an easy way to export a list of the artists and titles in the VDJ library to a text file? I use several web tools for clients to pick songs from the library in advance, and it would be much easier to update that if I could just do it straight out of VDJ.
geposted Mon 31 Dec 07 @ 10:40 am
To a text file, there arent such a tool no...
But if you know web apps, VDJ database is XML, and perfect for integrate/use at other enviroments, such as Web
geposted Mon 31 Dec 07 @ 11:12 am
Well, I don't host the web apps (either DJ Intelligence or Gigbuilder) - both just want a delimited text file. I'll have to see if I can hack something to parse the XML.
I'm using a third party app right now to create yet another database so I can then export that to text delimted, then hand edit in Excel, then upload. There's got to be a better way.
geposted Mon 31 Dec 07 @ 11:21 am
