Ive been working with controller mappers too long it seems. Now I am trying to compile a video transition of DJ Cels that uses Directx. I have Visual Studio Express 2008 installed and the Directx Nov sdk installed, but am unsure of how to tell Visual studio where to find the Directx Libs and .H files.
At the moment compile fails due to missing d3dx9.h.
Thanks
Thanks
geposted Mon 31 Dec 07 @ 8:51 pm
As you say, you need to set the folders up... under VS2005, set it under "Project > xxxxx Properties > Configuration Properties" - you need to select the configuration you are using (or all).
C/C++ > Additional Include Directories > "c:\program files\microsoft directx sdk (november 2007)\include"
Linker > Additional Library Directories > "c:\program files\microsoft directx sdk (november 2007)\lib\x86"
HTH :)
Regards,
Scott
HTH :)
Regards,
Scott
geposted Tue 01 Jan 08 @ 1:56 pm
Ahhh, knew it would be in there somewhere. Will give it a shot.
Thanks SBDJ
Thanks SBDJ
geposted Tue 01 Jan 08 @ 8:07 pm
You're welcome, good luck :)
geposted Wed 02 Jan 08 @ 10:11 am
