Hi, I want to use numark total control for the deck controls in vdj, and my x-session for the effects sliders and the samplers. TY.
geposted Thu 03 Jan 08 @ 12:22 pm
Ok I think it may work as 1 I believe is Native (if it is yes it will work) I use my MK2 along with my X-session.
geposted Thu 03 Jan 08 @ 5:49 pm
Yes you can use two controllers at the same time as long as one controller is H.I.D. & The other one is Midi. I use a DMC2 & the total control at the same time. It works great.
Keivan
www.PreferredDjs.com
Keivan
geposted Sat 05 Jan 08 @ 8:01 am
I did used general midi from the Pioneer Djm800 and Numark DMC2, so yes you can, but you can't use two midi controllers that use buttons for the same channels.
geposted Sat 05 Jan 08 @ 2:22 pm
