Dear Dj's,
I have maya 44 (before a herculles console mk2) on the computer but I have a problem.
The virtual I have dj 5.0 (registered version ) have therefore established the sound setup this way: inputs time code (use the time code cd's pro and ordinary & Time code vinyl) outputs external mixer, soundcard maya 44 (with the last new driver for vista.
the maya 44 control panel stand this way as adjusted monitor 1+2 and 3+4 inputs mute
and the input and output on entirely open (what means the word gang ?)
Now the problem is I have no time code indicator and if I do automatic setup I have no 100% also no time code indicator.
therefore I can make now, however, cue point and start but I am not possible to my earlier established cue point by that which no perfect time code indicator do not recover his true point in the track I think.
who can help me
thanks already
thx dimitri
who can help me
thanks already
thx dimitri
geposted Sun 06 Jan 08 @ 1:55 am
after trying something out.
it works with my Time code vinyl (the time code vinyl is made by virtual dj)
I have 100 % signal but it don't work with my time code cd's, I use Denon Dn-S3500
I don't now it no more
geposted Sun 06 Jan 08 @ 2:56 am
I know what the probleme is.
The 2 downloaded virtual time code mp3 (the normal en the pro ) are to loud.
I downloaded mp3 gain progr. en I change the volume to 80 %.
Now I have 100 % time code signal.
dimi
dimi
geposted Sun 06 Jan 08 @ 6:05 am
No the problem was that you had the Maya Input levels up to loud.
On the Maya Control panel (with faders)
First 4 faders (Monitor In) -- ALL Muted
Next 2 Faders (Input- checked for gang) -- 1/3rd level for Timecode CDs or just under 1/2 for Timecode Vinyl
Next 2 Faders (Outuput - checked for gang) -- FULL volume
If you are using Pioneer or Denon players use the Pro Timecode file.
If you are using anything else use the Commercial Timecode file.
geposted Mon 07 Jan 08 @ 5:53 pm
