want to try out sony vegas but i'm running xp64 and it will not load to xp64 only to a 32 system, is there a patch i can use or am i doing something wrong or will i have to re-install my home pc system down to 32
Tayla
Tayla
geposted Mon 07 Jan 08 @ 5:07 am
anyone got an answer to this
geposted Tue 08 Jan 08 @ 1:24 pm
I think if you right click on the exe, and choose properties, then compatibility, and then choose windows 98, or 2000, or possibly even xp (i don't know if it has that option, as I don't run 64) it should run in compatibility mode...
let me know if that works...
geposted Tue 08 Jan 08 @ 2:46 pm
thanks steve
will give it a go tomorrow and let you know
Tayla
Tayla
geposted Tue 08 Jan 08 @ 2:50 pm
You also may want to check out the user forum at sonymediasoftware.com. They have a pretty good user forum there. (Although their forum software needs an update.)
geposted Tue 08 Jan 08 @ 7:24 pm
steve
tried it out and it won't play ball, gonna check in sony forums thursday any other tricks i could try or is it a re install down to 32
thanks
Tayla
thanks
Tayla
geposted Wed 09 Jan 08 @ 5:53 pm
Hello again Tayla
I use AVS video editor and it works good and easy to use, I also had problems with sony vegas, but heard the latest version 8 pro is much better
heres a link for you to check out
avs video editor, download free demo here
http://www.avsmedia.com/VideoEditor/index.aspx
Hope this helps
Rob
Hope this helps
Rob
geposted Wed 09 Jan 08 @ 9:51 pm
rob12345 wrote :
Hello again Tayla
Hope this helps
Rob
Hope this helps
Rob
Hey Rob, I think the original concern for Tayla was the fact that he has a 64bit computer in which Sony does not support. It's my understanding that any 64 bit computer is going to have problems finding software to support it.. Though I might be wrong!
geposted Thu 10 Jan 08 @ 10:22 am
thanks fatkatz, how you doing, did you get the email for "the link" vids there you can use
thanks rob, been pushing that programme since i had milk teeth, great for ripping need something a bit more sony vegas style
Tayla
Tayla
geposted Thu 10 Jan 08 @ 10:38 am
