What's up Everyone,
Is there a midi map to use a button to toggle back & forth between pitch and scratch function using the jog wheels? Maybe a shortcut key?
Thanks in advance.
flex
Thanks in advance.
flex
geposted Tue 08 Jan 08 @ 7:53 am
you can assign a keyboard key of your choossing as shortcut for wheelmode
go to vdj config
keyboard shortcuts tab
click add
select your key by pressing it
chose all
chose wheelmode at the bottom of the list
configure the value for 0 if you want it as a toggle
go to vdj config
click add
chose all
geposted Tue 08 Jan 08 @ 12:51 pm
