Forum: Old versions
Topic: macbook pro+virtual dj+maya44+total control
i've mcpro and maya44 want to mix videos, can i use vdj4.3 if not wht version i can use. and if i buy a numark total control and it comes with numark virtual dj software can i use this software to connect with my maya44 because i've used with vdj4.3 but they say "the sound card driver error"
please help me.
thank you very much
geposted Wed 09 Jan 08 @ 6:39 pm
Pls register ur serial at ur modify ur page n grab the public beta which have improvement over 4.3. Thanks.
Once you have added your serial/ purchased pro
You can download V5 in which timecode is supported and follow the manual in the mac forum.
hope to see you with us soon as a pro user.
now i havn't got a serial due to borrow this vdj from my friend. if i wanna buy which way is cheapest one?
thank you
https://virtualdj.com/buy/ you need the latest VDJ pro to use timecodes on the mac.
You will be provided with a serial for both versions.
