I have 2 machines
1 has GeFroce 8600M GS
other has NVIDIA GeForce 8800 GTS PCIe x16 Video Card
640MB GDDR3 Video Memory
any views ?
any views ?
geposted Sat 12 Jan 08 @ 8:00 pm
I thought I heard Cyder say that there were issues with the 8800, dont quote me but I think it was that card ask him.
geposted Sat 12 Jan 08 @ 9:09 pm
i use nvidia and haven't as yet had any problems with their cards either running on xp or vista, mind you it is a dedicated lappy only for vdj, or i could just be one of the lucky ones not to have any problems
Tayla
Tayla
geposted Sun 13 Jan 08 @ 4:32 am
8000 series cards have had some issues with xp
geposted Sun 13 Jan 08 @ 7:35 am
does that imly its fixed with vista ? i have a 8800 runnin ok with vista but a 8600 gave me a mini freeze of 1 second video, then recover, i tweaked it to fix and I did fix it but the fix caused an audio skip at the beginning - this is all automix by the way, I then reversed my fix and checked 'safe mode' on performance setting ( also latency auto and overclocked unchecked, preset to fastest) dual core, 2gb, dedicated lappy hp, 540rpm hdd. its now working but I'm concerned what caused it - I have lappy on trial so need to decide
geposted Sun 13 Jan 08 @ 1:00 pm
Nvidia or ATI....which is better in general for VDJ Vista .......PC / Laptop ?
geposted Mon 14 Jan 08 @ 3:18 am
There was a time when ATI was the choice for laptops doing video.
Now its like Energiser vs Duracel, they both make light with you put them in a flashlight.
Is it Dave from London or Dave from Houston btw...???
Yer confusin me
r
Yer confusin me
r
geposted Mon 14 Jan 08 @ 1:50 pm
Davefromlondon lives in ..........Dallas TX :)
geposted Mon 14 Jan 08 @ 7:54 pm
http://www.newegg.com/Product/Product.aspx?Item=N82E16834115454
I am looking to purchase the laptop above with details below but in a nutshell it is a:
-CPU Type Intel Core 2 Duo T5450 1.66G
-Operating System Windows Vista Home Premium
-Memory Speed DDR2 667
-Memory 2GB ******(I PLAN ON MAKING THIS 4 GIG)***** **
-Hard Disk 250GB
-Graphics Card NVIDIA GeForce 8600M GS
-Video Memory up to 1024 MB of TurboCache (256 MB of dedicated GDDR2 VRAM, up to 768 MB of shared system memory)
-CPU FSB 667MHz
-CPU L2 Cache 2MB
-Video Port 1 x VGA, 1 x S-Video TV-out, 1 x HDMI
Does anyone foresee a problem in this? I did hear problems with the nvidia 8000 series having a problem but from what I also read, they were only with xp and people having 2 gig rams or below. If I have vista and bump the Ram Memory from 2 gig to 4 gigs and leave the "TurboCache" on will this video freezing and crashing still be an issue? Also, the S-Video out, is that where everyone outputs to the "big screen"? I've read quite a few forums regarding the issue I'm posting but I didn't really see a concrete answer for my situation, like I said, I saw mixed solutions/opinions. Anyone here have some input regarding this question. Any help would be much appreciated.
Thanks.
DETAILS ABOUT THIS LAPTOP:
Model
Brand Acer
Series Aspire
Model AS5920-6706
Part# LX.AN40X.528
General
Screen 15.4" WXGA
Memory Size 2GB DDR2
Hard Disk 250GB
Optical Drive DVD Super Multi
Video Memory 256MB
Communication Modem, Gigabit LAN and WLAN
Card slot 1 x ExpressCard/54 slot
Dimensions 14.3" x 10.6" x 1.2-1.7"
Weight 6.6 lbs.
CPU
CPU Speed T5450(1.66GHz)
CPU FSB 667MHz
CPU L2 Cache 2MB
Chipset
Chipset Intel PM965
Display
Screen Size 15.4"
Wide Screen Support Yes
LCD Features Acer CrystalBrite Technology
Display Type Wide XGA
Resolution 1280 x 800
Operating Systems
Graphics
GPU/VPU NVIDIA GeForce 8600M GS
Graphic Type Dedicated Card
Hard Drive
HDD 250GB
HD RPM 5400rpm
HD Interface SATA
Memory
Memory Slots 2 x DIMM
Memory 2GB
Ports
Card Slot 1 x ExpressCard/54 slot
USB 4
IEEE 1394 1
Other port 1 x CIR (consumer infrared)
Audio Ports Headphones/speakers/line-out with SPDIF support
Microphone-in
Line-in
Audio
Audio Dolby-certified surround-sound system
Dolby Home Theater audio enhancement
Microsoft DirectSound compatibility
Speaker Two integrated stereo speakers and one subwoofer supporting low-frequency effects
-Hard Disk 250GB
-CPU FSB 667MHz
-CPU L2 Cache 2MB
Thanks.
Model
Brand Acer
Series Aspire
Model AS5920-6706
Part# LX.AN40X.528
General
Screen 15.4" WXGA
Hard Disk 250GB
Video Memory 256MB
Weight 6.6 lbs.
CPU
CPU FSB 667MHz
CPU L2 Cache 2MB
Chipset
Chipset Intel PM965
Display
Screen Size 15.4"
Operating Systems
Graphics
Hard Drive
HDD 250GB
HD RPM 5400rpm
HD Interface SATA
Memory
Memory 2GB
Ports
USB 4
IEEE 1394 1
Microphone-in
Line-in
Audio
geposted Tue 01 Apr 08 @ 9:39 am
Hey Guys, I am having a problem with a new Dell latptop that I purchased to do video with VDJ. The problem is similar to the ones it seems that everyone is having regarding the stopping of the video while playing.
System Specs.
Dell Precision M 4300
Intel Core 2 Duo
T7250 @ 2.00 GHZ
1.99 GHZ, 2.00 GB of Ram
NVIDIA Quadro FX 360 M
I need this to work flawlessly I have a big gig this weekend with video.
Thanks for the help.
_lou
System Specs.
Intel Core 2 Duo
T7250 @ 2.00 GHZ
_lou
geposted Tue 01 Apr 08 @ 10:48 am
