Am I stupid?
I cant find the record button in VDJ trial. Or is there no record button?
Thanks,
Thanks,
geposted Sun 13 Jan 08 @ 12:26 pm
i recorded but i went to config tab upper right switched skin to mixlab and left lower tabs you will see record but they sit verticle it works awesome but i couldn't figure out how to read my ipod playlist and the techs never called me back so i am getting rane serato sl3.
geposted Thu 21 Jan 10 @ 8:38 pm
like the first person, i am totally lost. i dont see any record tab in the left corner. i bought the rmx 2 years ago or so and never used it. recently plugged it in and can't find the icon to record. can anyone point me in the right direction? i currently run the vdjle version it came with.
geposted Fri 23 Apr 10 @ 10:43 am
its in the upper right
geposted Mon 26 Apr 10 @ 3:58 pm
How do I save my mixes and record them on cd?
geposted Wed 16 Jan 13 @ 10:07 am
I've struggles with the built in record function within VDJ, my setup causes all sorts of funny things to play back.
To get round this, split my master out to the speakers, and back into my soundcards line-in, and then record through Audacity, a free download - http://audacity.sourceforge.net/ - then you can edit (balance, normalise, split into individual tracks), save, and export the track as mp3, wav, whatever, then burn the saved track to CD with Windows Media Player.
Note:
Using Audacity, you can split the long recording into individual tracks, then save it. If you split it, then export as 320bit mp3, you will get a tiny gap between the tracks when you play it back. To avoid this, export as wav.
Mike
geposted Thu 17 Jan 13 @ 1:17 pm
I have just purchased a mixtrack quad and I'm using the suggested skin for virtual dj 8, but I can't seem to locate the record button?
geposted Wed 29 Jul 15 @ 11:57 am
You should open your own thread. This thread is very old.
geposted Wed 29 Jul 15 @ 2:13 pm
how to record my remix? please teach me
geposted Thu 05 May 16 @ 4:21 am
What do you need to know? To record, press the record button.
geposted Thu 05 May 16 @ 5:16 pm
if you don't see the record button then go to the configuration where there is a record tab. After you choose record start go back to the skin and there should be a node illuminated that was not before.
geposted Tue 10 May 16 @ 7:03 pm
I have same problem - Where is the configuration?
geposted Thu 05 Jan 17 @ 9:52 am
https://virtualdj.com/wiki/PDFManuals.html
For simple features like this the manual is where you begin.
geposted Thu 05 Jan 17 @ 1:52 pm
HEY I'M FACING PROBLEM IN RECORDING IN VIRTUAL DJ 8. I RECORD SONGS FROM SETTINGS>RECORD AND WHEN I CLICK ON START RECORDING IT IS SHOWING TO ME -"could not open file for writing". please tell me what to do in this problem. plz plz plz friends help me.
geposted Mon 03 Apr 17 @ 10:34 am
I have the problem of the chap up above ☹️
geposted Wed 05 Apr 17 @ 3:41 pm
Have you two read the manual as described in the link above, because this thread is very old, as in ancient?
geposted Mon 17 Apr 17 @ 6:21 am
The message you receive is probably related to write permissions to a Folder. Try to change the recording destination to Desktop or other
geposted Mon 17 Apr 17 @ 2:52 pm
I don t see "CONFIG" button in vdj 7. I have beatmix reloop with asio soundcard.
geposted Sun 08 Apr 18 @ 11:32 am
Read the manual. If you don't have the manual, download it from here:
https://virtualdj.com/wiki/PDF%20Manuals%20-%20Legacy%20Products.html
geposted Sun 08 Apr 18 @ 11:48 am
it will possible repair with reset skin tool ?
geposted Sun 08 Apr 18 @ 12:16 pm
