Any preferences?
geposted Sun 13 Jan 08 @ 9:59 pm
ok, does anyone have any experience with either of these at all?
geposted Mon 14 Jan 08 @ 6:27 pm
depends how you are going to use them, do tou need sampler or not, do you like buttons or touch pad for starters pio 500 is the best choice.
I would get the kaoss pad 3, is the latest of them and they are dedicated to effects anyway I'm happy with just the djm 800
geposted Mon 14 Jan 08 @ 7:29 pm
I've had experience with the Kaoss pad, and it's amazing, the EFX is OK i guess, but the price is murder, IMO, go with the Roland SP-404
geposted Tue 15 Jan 08 @ 4:12 pm
I'm borrowing a boss sp-303 right now but I just don't think I'm very happy with it. Isn't the sp-404 basically the same thing?
geposted Tue 15 Jan 08 @ 5:59 pm
I have the SP-303, I think it is the same as the 404, only with more sampler banks and the 404. The 404 doesnt use smart media cards, I think now they are using SD or CompactFlash.
But using the SP-404 or SP-303 as effects box??? Yes it can but it is not the same as an EFX box.
I recomend you that go to a local store (Guitar Center or somthing similar) and play with both and pick the one that covers your needs.
geposted Tue 15 Jan 08 @ 7:15 pm
