Anyone else notice that when using the 'brake' or 'backspin' effect to completely cut a song to silence that there is a tiny 'click' or 'blip' sort of sound that occurs right after the effect has finished.
It is extremely annoying!! Any feedback welcome!
Using VDJ 5 rev 6 with a numark dxm01 twin usb soundcard mixer in the correct setting. As far as I know this has been an issue for most of the VDJ 5 releases.
Cheers
Cheers
geposted Tue 15 Jan 08 @ 5:55 pm
never had it before with any version. what bitrates are your audio files? have you tried a higher latency setting?
geposted Wed 16 Jan 08 @ 7:34 am
Yes it's a known problem with the current code of these effects
geposted Wed 16 Jan 08 @ 12:27 pm
Thanks for the response, any one know of a fix eta? Or is it something unavoidable.
geposted Wed 16 Jan 08 @ 4:41 pm
Thats been an issue for a min... I have yet to see a fix... If anyone knows of a fix or work around please let me kno... The click/pop at the end of backspin is really annoying....
geposted Fri 15 Feb 08 @ 5:28 am
