I have been using 4.3 for the past several months with very little problems but VDJ crashed (No crash guard) then all the contols froze for about 30 seconds and then player A just stopped while using the brouser. I am hoping this is just a fluke as 4.3 has been stable as opposed to the newer 5 versions.
My specs:
Vista
3.0 Intel dual core
8800 GTX
4 Gig Ram
M-Audio Fast Track Pro
M-Audio XSession Pro
Anywhere I should look at?
Thanks,
HOP
My specs:
Vista
3.0 Intel dual core
8800 GTX
4 Gig Ram
Thanks,
HOP
geposted Tue 15 Jan 08 @ 8:23 pm
Could be something Windows caused. Did you check the Event Manager to see what happened at that time?
As you say it's been stable up to now. The worst thing about PC DJing is that PC's are still likely to crash.
Hope you find it's a 1 off.
geposted Wed 16 Jan 08 @ 7:38 am
Same thing happened to me with V5. My virtual DJ has never been more stable than with V5, then about 2 weeks ago out of nowhere it crashed. Was so bad I had to do a clean reinstall.
geposted Wed 16 Jan 08 @ 3:49 pm
