PPL I HAVE THE BCD2000, A MAYA 44 USB AND MY TCVS N I CANT GET IT TO PLAY
CAN SOME ONE HELP ME HOW TO CONFIGURE THIS SET UP PLZ..
IM TRYING TO USE THE BCD2000 AS MIDI CONTROLLER ONLY...
THE MAYA AS SOUND CARD BUT IT DOESNT WORK...
ALWAYS SAY "ERROR WITH THE ASIO DRIVERS"
geposted Thu 17 Jan 08 @ 11:14 pm
Please do not type in the forums with CAPS LOCK engaged. It is interpreted as shouting. Hang in there, someone will be along to help with your issue. Check back often :)
geposted Thu 17 Jan 08 @ 11:32 pm
lets see, let me rub my crystal ball and see exactly what you've done..... nope, not getting anything. please explain exactly what you have done otherwise RTFM.
geposted Fri 18 Jan 08 @ 12:27 am
Try reinstalling the maya drivers, that is usually the cause of that error message.
geposted Fri 18 Jan 08 @ 5:49 am
ohh sorry for the CAPS ... and for not explaining myself..
but well basically what i had done is plug da turntables to the maya 44..
and the maya to the bcd...
for the config. in vdj i put the maya as asio drivers... and midi for midi
i installed the maya drivers also.. i have the cd.. plz help ppl thank you.
geposted Fri 18 Jan 08 @ 5:55 pm
Let us understand and give us some right info. You want to use your bcd as a mixer and controoller and use time codes without external mixer right?
Also wich version of vdj are you using?
geposted Sat 19 Jan 08 @ 7:27 am
hi im gattoriko,, i just got a new account and bought vdj software.. but i lost my e-mail password so i had to make another one...
and yes gluzantzas thats exactly what im trying to do.
geposted Sun 20 Jan 08 @ 5:41 pm
First of all welcome to the club.About your topic go to confiq>sound setup and choose inputs 2 timecodes and on outputs select headphones.
Select as soundcard maya asio drivers and at athe bottom of this window om output channels sellect wich channel you want for master and wich for the headphones
Perfer to choose the line that has minijack output on maya for headphones for practikal reasons.
The final step is to enable your bcd on confiq>remote control.
I hope that this works :)
geposted Mon 21 Jan 08 @ 7:08 am
if you wish to transfer your Tcv registration you can
contact support
The bcd has some potential hardware problems you should check out if your experiancing these by checking for irq conflicts.
http://www.helpwithpcs.com/upgrading/change-irq-settings.htm
geposted Mon 21 Jan 08 @ 7:36 am
thanks everyone for helping me i will try and see what happens =)
geposted Tue 22 Jan 08 @ 3:15 pm
