im between those 2, but im not sure which one to choose????
any suggestions? good or bad :)
cheers
cheers
geposted Sat 19 Jan 08 @ 10:15 pm
The question is do you need a souncard , if so the xponent.
Remember you will need pro to use either and you can get it at a
discount.
discount.
geposted Sun 20 Jan 08 @ 3:37 am
the thing is that ill probably get a sound card anyways, so i can connect my vinyls with tcv
i was just wondering which console is better as in features and support from virtual dj. im a big fan of VDJ and i dont think i would feel comftable with any toher dj program
so i want to buy a console that will have best support from vdj
cheers
cheers
geposted Sun 20 Jan 08 @ 8:08 am
Currently the is natively supported i use mine alot and it performs well for me , VCI will aslo be natively supported soon hopefuly.
they both feature touch sensitive jogs , and are high end controllers , if you are low on space get the VCI as the xponent has larger jogs and buttons and more assignable faders it takes up more room
geposted Sun 20 Jan 08 @ 10:56 am
