Hey all,
Just wondering when I auto configure my timecode quality never seems to be at 100%? Anyone know how to help me thanks
DJK
DJK
geposted Wed 23 Jan 08 @ 8:25 pm
Better post your hardware details... like fully... because thats the first thing they will ask...
geposted Wed 23 Jan 08 @ 9:23 pm
Im running 2 Technics 1200mk2 with a m-audio conective sound cars, a rane ttm57sl, my laptop is a dell xps 1330 intel (r) core(tm)2 duo t7300 @ 2 ghz and virtual dj timecode vinyls also using vista as my operating system
geposted Thu 24 Jan 08 @ 3:31 am
Which needles do you use? , the best to use are Ortofon concorde Digitracks because they are specialy modified for the timecode signal?
http://www.decks.co.uk/products/carts_styli/ortofon/concorde_digitrack
What latency settings do you have set on options > Performances
geposted Thu 24 Jan 08 @ 6:10 am
so far as you are not using anything like vitual vinyl sound card for virtual dj or virtual vinyl itself, the best u can get is only one side being 100%. however, if your time codes are working well, then you don't need to worry about the 100% issue or else you'll continue to buy and buy more gadgettes. meanwhile, on the timecode configure, select: clear sound, smart cue, and alternate auto configure with software RIAA preamp
geposted Mon 28 Jan 08 @ 3:14 am
