Hi,
I got 2 M-Audio Delta cards, each with 2 inputs : analog and SPDIF.
My 2 turntables are each connected to the analog (RCA) inputs, one in each card.
The problem is that in virtual DJ there is only the option to select either input channel 1&2 or 3&4 ... but 3&4 is the SPDIF input ... i need to select channel 5&6 ...
geposted Thu 24 Jan 08 @ 4:02 pm
any help please ... thanx ...
i've already tried the ASIO4ALL driver, but when i select this driver, VDJ doesnt play any sound anymore ???
I've also tried to set the numInputChannels key in the registry as explained in some post, but there's no such key on my machine ...
any help please , i'm stuck ...
thanx
thanx
geposted Fri 25 Jan 08 @ 4:08 am
just get a proper 2 stereo (4 channel analog) input card or get a tt or cd with digital out and connect it to the digital input, or use another stand alone card that will take analog input and output digital, then connect one of the tt to the first card analog then the digital output of the first card in to the digital input of the second card, maybe you can daisy chain your m-audio cards and connect just one to the computer, use one just as analog to digital adapter
geposted Fri 25 Jan 08 @ 10:23 am
