Saturday night with 2,06 without problems (only one : I can't pre-listen with right click in Asio mode)
wishes For the next update :
1) Direct Access to Favorite folders (example:to press "Q" to go to "HOUSE 2004")
2) Direct Access to File information and analize -
3) Pre listen - if I'm playing a song in channel 1 it could be good if you press "pre-listen key" and that the sound was listened by chanell 2 and the same thing but to the inverse one -
4)Another style of Playlist ...maybe like Pcdj
5)If we are using asio soundcard : Assignable Samples to another soundcard without asio drivers
6) Better BPM detection
Thanks for the good work
geposted Sun 28 Nov 04 @ 8:08 am
can you send more information about UC33e Mixtable please ??I will buy it . I want to know if some problem of compatibility exists with maya 44 usb .
Thanks
Thanks
geposted Tue 30 Nov 04 @ 3:37 am
what's up mang
so, you can listen to the song on opposite deck before playing though right?
what type of set was it?
geposted Tue 30 Nov 04 @ 4:09 am
I'm referring to listen the "another" song WITHOUT LOADING IT !!
geposted Tue 30 Nov 04 @ 4:19 am
you dont know what songs you're playing?
i usually have a pre-ordaned set i am going to play. especially with hip-hop.
if im mixing house, or trance, it could be anything goes. it wouldnt matter exactly how i played certain things.
i will spin that from time to time.
im more of a hands on DJ though.
all the messing around should have been done beforehand. (the set that is)
geposted Tue 30 Nov 04 @ 4:50 am
