Question about Virtual DJ open engine plug-in
I was testing pcdj-vj (the virtual dj engine ) with my Vestax vci-100...map it out ....all OK
and then I thought about testing my mixvibes DVS V2 time-code vinly with the Virtual dj engine in PCDJ-VJ
I did not think it would but I give it a'go anyway....
it did worked...I got 0% time-code quality...but it worked
it was all good...no pop's or click's...low latency with my EDIROL FA-66 SOUND CARD and good sound quality
for the frist one to two minutes its all good and then it just stop working
so my question is with the open engine will I get 100% time-code quality with my mixvibes dvs time-code vinly
and will I be able to use the hole 14 minutes of the time-code vinly
geposted Tue 29 Jan 08 @ 12:48 am
mixvibes vinyl is not natively supported you would need to create a timecode plugin to support that vinyl.
geposted Tue 29 Jan 08 @ 6:51 am
Is it supported (absolute, relative and smart-relative) in Virtual DJ 7 Pro?
geposted Wed 27 Oct 10 @ 6:56 am
