i have:
numark tt100 turntables
hercules mk2
virtualdj 5 pro
Do i just need the timecoded vynil and thats it?
Or do i need a mixer? Cant i just use mk2? A bit confused on how to set everything up.
Thank you for you help
DJ reNe
hercules mk2
virtualdj 5 pro
DJ reNe
geposted Thu 31 Jan 08 @ 3:51 pm
You will need two TCVs, if you intend to use the TTs. The Herc Mk2 will work with the setup, tricky but it will work.
If you are NOT going to use the TTs, then the Helc will work with VDJ as it is, because the Herc MK2 has a built in sound ASIO sound card.
geposted Sat 02 Feb 08 @ 10:03 pm
