everytime i go to a site or into a store i get the same responce all cd roms and dvd roms will read a cdg disk its all about the software you use to read/see it, not the rom drive you use. well theres so many ppl on here that have problems ripping cdgs i have found out the awners to how to do that part now i just need to figure out how to get it there in the first place.
ive looked at a few places and finallly found a cdg rom but its been discotinued or somthing to that efect.
im jsut starting to get what packages i want to get started with figured out so i dont have any disks at this time but they will be coming by mid Febuary
please can someone finally clear this up once and for all (and if able post a link to get it)
thanks Rockinrossco
thanks Rockinrossco
geposted Thu 31 Jan 08 @ 4:47 pm
What is CDG??
geposted Thu 31 Jan 08 @ 5:01 pm
cdg= cd with the kareoke graphic
geposted Thu 31 Jan 08 @ 5:07 pm
in my running around the net to find a few thinks i came across a hybrid cd for karaoke disks. has anyone tryed them out and are they a viable sorce able to make a complete colection (are there just as many song in hybrid as cd+g) whats your experiance
heres the link where i found an explanation
http://www.karaokewh.com/karaoke-hybrid-cdg-definition.cfm
geposted Sun 03 Feb 08 @ 3:34 pm
