Hello!
I have a hercule console, that I must use vith atomix mp3. The problem is that I've lost the CD to install the software on my compunter. Is ther any solution to get an other one?
Thank you for your help
Julie.
Julie.
geposted Fri 01 Feb 08 @ 3:56 am
Hi, this might do it.
Go to Downloads>Software updates. Enter your password that you use to get into the forum, It then should bring up your Serial Number and the software you can download from it.
Click on the software to download it.
I hope this helps
Jimmy b
geposted Fri 01 Feb 08 @ 9:18 am
Contact Hercules Support
http://www.hercules.com/uk/support-faq/
geposted Fri 01 Feb 08 @ 5:27 pm
