I tried running this option and nothing ran...i'm doing this because there are files that are popping up that are on different drives that aren't present.
am i in the right place and is this feature currently working?
geposted Fri 01 Feb 08 @ 2:55 pm
Ya, I ran this option too and it didn't seem to do anything.
geposted Fri 01 Feb 08 @ 5:08 pm
still seems to not be working in latest release.
geposted Mon 04 Feb 08 @ 3:44 pm
i will investigate this further for you.
geposted Mon 04 Feb 08 @ 5:56 pm
I've mentioned this several times Simon, and it really doesn't do anything on the MAC version...yet that is.
I'm hoping it will be implemented in later versions ;)
geposted Tue 05 Feb 08 @ 5:30 am
anything yet sky?...this is getting annoying...i know i can just delete then start over but that will also erase all my bpms. also, when i make autoplay list, I can't tell
which songs it will play and which ones it will skip because it can't find it.
geposted Thu 07 Feb 08 @ 12:39 am
It will need to be addressed in a quick update the dev team are in america with numark this week so a fix hopefully can be investigated at the weekend.
geposted Thu 07 Feb 08 @ 11:44 am
oh ok..so this is something that you duplicated then and not just me...ok...thanks for the reply.
geposted Thu 07 Feb 08 @ 3:38 pm
