Before to buy VDJ I want to know which laptop is the best for VDJ. So please let me know if you guys know something about it. Thanks..
geposted Fri 01 Feb 08 @ 11:44 pm
What do u want to achieve? Video + Audio or audio only? Using external hardware and timescodes?
There a lots of good lappy ard.
U must tell more specific so we will be able to suggest what kind of set up for u:)
But i may say that one of the solution is to go mac:)
geposted Sat 02 Feb 08 @ 6:53 am
I want to do both but music is my priority. I check the Dell laptops and I like it because it comes with a extra soundcard. Also I checked the Hp pavillion laptops and they look pretty good. And finally I check the new mac and is an amazing maching...So please give me some advices base on your experience so I dont make the wrong decision. Thank you....
geposted Tue 26 Feb 08 @ 11:39 pm
Can u say ur bugdet?
A lot of user use dell n HP, n im one of the HP lappy user, n i quite happy with my HP performance. Get a lappy that at least have duo core processor n at least 2gb n a lappy that have the dedicated memory not shared. With tweaks n minus off useless programs ur machine will certainly will be good to go. Harddisk size is secondary as to me its betta to have the external for ur songs n the internal only for programs;) And lastly u need to have legal VDJ Pro too for it to werk good;)
As for Mac, The macbook is enuff but as u say u wanna use both (Audio n Video), It best to get macbook pro. This is due of its graphics card. On mac u could use OSX n windows together, but i dare to say that i use VDJ natively on mac n so far no "major" problem. All is well.
One things to considered also upon all this is that the OS (XP, Vista, OSX tiger, OSX Leopard) do make a different.. but overall the bottomline is if u config ur system correctly, u shouldn't have any problem;)
Regards.
Regards.
geposted Wed 27 Feb 08 @ 12:13 am
Thank you for your advices. Now I have a better idea of what to buy...Thanks
geposted Wed 27 Feb 08 @ 8:12 pm
