Gang -
I just got the above mentioned card. Using the generic WDM driver, VDJ (and PCDJ) both have volume discrepancies. One channel set is lower volume than the other.
For compatibility, I would prefer the generic driver vs their driver. Does anyone else know of this issue and have a solution?
Thanks gang!
Thanks gang!
geposted Sat 02 Feb 08 @ 10:09 am
odd..
Does the soundcard have its own control pannel program, where you can level out the differences?
geposted Sat 02 Feb 08 @ 2:02 pm
Well, using the WDM driver, both apps are impacted. Use the AISO driver, and VDJ sounds same on both. PCDJ (still using the WDM) has a sound discrepancy.
No control panel app. This is under W2K.
geposted Sat 02 Feb 08 @ 3:59 pm
Me thinks the solution is awkward...
Channels 1&2 and 7&8 are the same for some reason.
So I used 7&8 vs 1&2 b/c the volume is normal.
Using the generic driver, both RED and VDJ seem happy.
I *might* reinstall the ESI driver since I know this does work - worst case, no ASIO for VDJ.
Ya see, I am retooling my main rig.
geposted Sat 02 Feb 08 @ 5:33 pm
I dont know the giga soundcard myself, but glad to hear you're on the path of a solution :)
Hope you can figure it out.
geposted Sat 02 Feb 08 @ 5:37 pm
