Just bought Vegas 8 for $185 delivered.
B&H Photo
Buy Vegas 6 for $79 and the upgrade to 8 for $99.
Good deal from the SSL site
Thanks guys
B&H Photo
Thanks guys
geposted Mon 04 Feb 08 @ 7:06 pm
Your not talking about Los Vegas, United States tickets are you? lol
I wish it was that cheap
geposted Mon 04 Feb 08 @ 9:13 pm
Vegas Studio, Vegas Platinum or Vegas Pro? I called their site and the Vegas 6 they said was not the Pro version and the PRO 8 upgrade did not work with it unless you had vegas 6 or 7 PRO originally......did you get your 8 pro upgrade to work with the 6 you bought?
geposted Tue 05 Feb 08 @ 2:20 am
Rick,
Just to let you know, I've personally spoken to two highly regarded videographers here that had recently upgraded to Vegas 8 and after working well for a short time, the program completely crapped out, and they've since had to reload a prior version. As of last week they've had no response from the mfg as to why, or when a fix would be available. But they did also mention that several more that they have spoken to were having the same issues. Just thought I'd let you know.
geposted Tue 05 Feb 08 @ 8:07 am
You buy 6 pro and upgrade it to 8 pro
I just talked to B&H and they said you don't even need to install 6, just enter the serial into the upgrade to 8 and it will work perfectly.
6 is an oem version cd only btw, 8 is the full boat version.
geposted Tue 05 Feb 08 @ 8:08 am
Some of you may find this EXTREMELY interesting.
http://www.youtube.com/watch?v=iYFG_H7fq_g
If this isn't for you - don't hate.
geposted Sun 23 Mar 08 @ 2:13 am
Rainbow six las vegas 2? I got mine cheaper than that!
geposted Sun 23 Mar 08 @ 5:08 am
