I currently use Pro with the MK2 and I am adding 2 turntables and going to use the MK2 for ASIO. My only question is once I do that with a external mixer, how will the video feed be switched, will I still be controlling the video fade with the MK2 or will have to do that on the program itself?
geposted Tue 05 Feb 08 @ 10:20 am
you can use DJS cels mapper to alter the crossfader to just crossfade the video
or you can use a keyboard shortcut , the better solution for this would be to use a midi mixer like the nuo4 however which will control the video and mix the audio at the same time.
geposted Tue 05 Feb 08 @ 10:25 am
This might sound stupid ... but what is the DJS cels mapper?
geposted Tue 05 Feb 08 @ 10:38 am
It's a MIDI mapper for the MK2, that allows you to make the controls do just about anything you want.
You can find it here, about halfway down the page ;)
geposted Tue 05 Feb 08 @ 11:07 am
Thanks guys!
geposted Tue 05 Feb 08 @ 11:23 am
