ive been looking around for a new wireless mic setup and found that most of them are singlemic and table top set not rack mount and the antennas are in the back and this just wont work for me so looking to you all for some advice on what to get and whats better or differance between uhf and vhf
what i need
rack mount
front antennas
two channels
if possable, adjustable frequancy
i was looking at a vocopro that met all the stuff above but was told it was crap by the guy at guitar center
the vocopro that im talking about can be found here http://www.vocopro.com/frm_product.html its the uhf 6800 model under the wireless mic area
thanks rockinrossco
what i need
rack mount
front antennas
two channels
thanks rockinrossco
geposted Thu 07 Feb 08 @ 10:44 am
Well first off look at this.. http://www.pssl.com/Search?@p6&q=Wireless+mics and then look at this http://www.pssl.com/Behringer-UL2000M-Handheld-UHF-Wireless-Mic-System it comes complete with a rack mount included in the price. I have not used one...but it looks good. Multi channel is important to move the freq. when you get interference.
geposted Thu 07 Feb 08 @ 11:16 am
http://www.skytronic.co.uk/product/product.php?s=171.316
http://www.kam.co.uk/products/mics/vhf_wireless_mics/prod5.htm
I have the first one its ok I don't want anything more expensive as it's for karaoke, It has a mixed XLR on the back so that you have one lead from the back of the unit to your mixer and then both mics work of one channel saves messing around with two sets of eq's, there is a bit of feedback when the two mics come together however iv fitted a FBX 2400 fedback destroyer I have not tested it yet I'll keep you posted.
geposted Thu 07 Feb 08 @ 4:26 pm
This might cost a little much but it is "pro" in every way. You get what you pay for with wireless...
The Sennheiser EW135 G2 system has tons of available frequencies and the needed features you will ever need. The mics are awesome sounding and they use "AA" instead of the costly 9 volt. THe three systems I own has never failed me for DJ and live band use in the past three years.
They sell adapters to move the antenas to the front next to the receiver.
What ever you decide, my advice is you don't go cheap! Buddy of mine crashed and burned on a Nady (Crap) system in front of 3000 people with his bass setup... tried to warn him to go hard wire but he did not listen - very ugly!
Hope I could help!
HOP
Hope I could help!
HOP
geposted Fri 08 Feb 08 @ 3:47 am
I was disappointed with Sennheiser radio mics as they are made in China, I bought one and the switch broke the first time I used it from just taking it out of the box. I do use Sennheiser lead mics as they are made in Germany still however a recent test I did between the SM 58 and the E35 favoured the 58 in the blind fold test with 17 people so I'm going to Shure with the lead mics and cheap with the radio mics as there only for karaoke use and not my own. Also I found out the Senn mics are knows as female vocal mics in the industry.
I am surprised you rate them.
geposted Fri 08 Feb 08 @ 9:07 am
What about Shure microphones? They are real good.
geposted Fri 08 Feb 08 @ 10:03 am
I use Shure PGX series radio mic. I have an SM58 head, it uses the AA batteries. Antennae are on the front, its UHF, you can get a rackmount kit and it will scan for channels so no interferences.
All in all its a really good set up. I've been using it a couple of years now, no damage and it still looks new after using it 4 nights a week.
Also comes in its own sturdy flightcase.
SHURE PGX24E/SM58 R1
Shure PGX24E/SM58 R1, UHF-wireless-system with SM58 handheld transmitter, 76 frequencies in 10 groups switchable (8 Simultan), automatic frequency selection, IR-frequency-transmission from reciever to transmitter via Sync function, 20 MW hf-power, HF- and audio LED on reciever , group and channel display, XLR- and jack out, to use with 2x 1,5 Volt AA, in plastic-case incl. power-supply, frequency-range R1 (800 - 820 MHz) This wireless system is only licensed for use in Germany. If you want to use in other countries, please ask for possible frequencies.
http://www.thomann.de/gb/shure_pgx24esm58_r1.htm
You can pick them up for about £300
Gary
Gary
geposted Fri 08 Feb 08 @ 12:24 pm
I use the same mic. I've had it for 2 years and it's like new. It also produces a good sound for my type of voice ( its a keeper for me )
geposted Fri 08 Feb 08 @ 12:35 pm
Charlie,
I have never used the (Cheap) Sennheiser wireless so I can't comment.
I do notice the majority of acts coming through here usually gives me some type of Sennie wireless being instrumental or vocal to plug in the sound system. Yes, the very last Sennie vocal mic was fom a girl out of LA... (your chick mic reference)
Most of the musicians that have not used the Sennheiser would prefer a Shure 58 (It still is the standard). Never has a complaint and some have even converted over to the Sennie after using it on stage (the difference they can hear in the monitors). I use the 135 module and I think it is really smooth and not quite as "industrial" as a 58. This is all personal preference at this point, so...
...try the mic before you buy and DON'T BUY CHEAP!!!
geposted Fri 08 Feb 08 @ 5:00 pm
thanks you all well i guess that does it to the idea of vocopro, ive had a shure mic for many many years and gone though a few cables but the mic has lasted as perfect as could be i think ill have to look at the shures and try to convince the wife to let me get it ( its always a battle to even get a new wifes and stuff)
but i have used a gemini dual wireless for many years and it sounded really good (suprizingly) but it finally gave out so its time to upgrade i guess
so thanks you all for your input it has kept me away form a bad choice.
geposted Sat 09 Feb 08 @ 11:32 am
