When i play music video such as (say it right) and pause with out hitting stop and then load another video such as(Feedback) on the same side as (say it Right) for some reason you will see the video (feedback) but you will here (say it right). Just wanted to report the problem. I have a macbook pro cen/duo 15inch. with virtual vinyl. I aslo here a distortion will im playing a song with virtual vinyl with the time code cds. until i take off the time code button on the program the distortion goes away. I also use numark total control with virtual vinyl. Has anyone also have had any of these same problems please report them or any other problems you have found.
geposted Thu 07 Feb 08 @ 12:31 pm
In config > performances and choose auto latency this should clear up your distortion.
are you saying that the decks are the wrong way round if so change the channels the opposite way round in sound setup.
if you are saying the new video is playing music from an old track that is troubling i haven't seen this before.
geposted Thu 07 Feb 08 @ 1:51 pm
With the new "video on mp3" function, is there any chance that dragging a video file to the preview window would replace the current video but not audio?
If so, that would actually be a cool function!(I haven't had time to test yet, will do it later tonight) I can see how that would confuse some users though...
geposted Thu 07 Feb 08 @ 2:04 pm
Only if you dragged it onto an existing video , if it is loaded onto the preview while an mp3 is played it will link ok , you can drag it back off to break the link.
geposted Thu 07 Feb 08 @ 2:19 pm
That was my point! If you drag a video to the preview window of an already loaded video, wouldn't that link the video from the new file to the audio of the already loaded file?
That would at least explain why he gets the audio from "Say it right" with the video from "Feedback"....
geposted Thu 07 Feb 08 @ 3:48 pm
Eek i assumed that a video cant be linked to a video but after more experimenting it can , what you need to do is click whist pressing apple + ctrl at the top of the browser and a menu will come up with possible fields you can choose choose video link then click whist pressing apple + ctrl and then you can choose unlink video.
geposted Thu 07 Feb 08 @ 4:13 pm
that is a neat feature though!
to me this is a feature gain and not a problem..hehe..nice to find out ;)
geposted Thu 07 Feb 08 @ 7:02 pm
