Hi ive got the latest version on vdj pro having problems with my numark total control midi interface well one actually set the interface up by going to the midi section in config selected total control, everyting works fine apart from when you try and mix the jog pads should be sensitive when moving to touch up or down but vdj it is slow and stops and carries on, making mixing impossible! it works fine with the bundled ( numark cue light) software everythings responsive but not vdj why is this? ive bought vdj pro as there are more options on it and numark cue le is basically the same engine, has anyone else had this problem or can anyone help i would feel cheated by atomix if i had to purchase some more software and as it has an option to use it in the program it should work. Im dj at a bar tommorrow and i wanted to use the software all the effects and the record option which is what i bought it for, any help will be most appreciated
geposted Fri 08 Feb 08 @ 12:28 am
What is your system specification?
try this go to options > performances
and set autolatency , and the slider to fastest untick safe and overclock modes.
geposted Fri 08 Feb 08 @ 3:58 am
Its a hewlett packard dual core laptop 1.7 intel core duo, 1 gig of ram using edirol fa-66 soundcard and internal headphones for cueing.
Ive tried what you suggested but still no better any other ideas? has any one else had the same problem?
geposted Fri 08 Feb 08 @ 10:41 am
oh and im using windows vista
geposted Fri 08 Feb 08 @ 10:42 am
are you useing the MIDI map provided by Moramax? also is it in stratch mode?
I use the newest version with mine and it works perfectly
geposted Wed 18 Mar 09 @ 11:20 am
