Forum: Old versions
Topic: Looking to go further - Page: 1
hey guys i am currently using the trial version of virtual dj and i need some info before actually buying it. I wanted to know some good and affordable turntables i can use with it. And i need to know what else i would need to get it all working. thanks
geposted Sat 09 Feb 08 @ 9:28 pm
With time-codes you need a good set of direct drive turntables , you could look at the numark direct drive battle back these are a good package for midrange users.
You will need good cartridges i would advise you to get Ortofon Concorde Digitracks this is what i use and they are specially modified to work with binary / time-code records and they will ensure a perfect result.
Now you will need a 4/4 interface like Virtual Vinyl , U46DJ , Maya 44 usb and you will probably want a mixer if you want to mix video it is advisable to get a midi mixer like the nu04 that way when you crossfade it mixes the audio output of the sound-card and moves the video crossfader in the software giving you a seamless mix.
If you purchase the Virtual Vinyl interface from Numark you also get Cue (VDJ pro) included.
i was thinking of get the numark tt200s.....
now what i dont understand is what all of those things are for....i was looking on youtube and their is a video on how to connect the turntables, mixer, and the sound card....i thought that was all i needed but i guess not...
now what exactly are the cartridges and the 4/4 interface vinyls and the maya 44?
Numark tt 200 are Numark ' s Entry level direct drive turntables , if you want to do some serious scratching check out the digitaly enchanced ttx / ttx usb :
or the analog version tt500 :
Cartridges contain the needle and take the signal off the vinyl.
The 4/4 interface is a special type of sound-card which has 2 stereo phono inputs and two stereo phono outputs
this is needed to allow using two time-codes and a mixer.
For example Virtual Vinyl which also includes Cue Pro (Vdj pro)
thanks alot man you've helped me alot..... Is there a video or something that will tell me how to hook all this up? I wanna be sure on how to do everything before i actually start buying
Here is a great video from DJ Soccros who explains how it is all setup he uses the sl1 box as an example
If you purchase Virtual Vinyl you get a full setup guide for the VV version of VDJ.
as well as this forum and tickets you can also use the numark support line.
thanks and what exactly is a time-coded vinyl??
sorry if I'm asking too much :/
Time Coded Vinyl is a special record on which instead of audio is computer code , so when you perform an action on the record the software knows to copy it.
So you can scratch your mp3 and videos on real vinyl and mix with a real mixer.
They are the main reason really for using turntables with virtual dj you can also mix normal vinyls if you use bypass mode.
oh ok thats what i thought it was i was just trying to make sure i was right...
thanks alot man
Your welcome its always better to ask and be safe rather than sorry :)
Is there any difference between cue pro and virtual dj pro?
Cue is sold via stores in box updates are available online , Virtual DJ Pro is sold online as a download.
They are the same except for the branding.
as an owner of the numark battle pack...i HIGHLY recommend saving your money and staying as far as possible away from this junk-in-a-box...biggest waste of $400 i've ever spent in my honest opinion
i just picked up a used set of technics 1200mk5s for $600 bucks off ebay, and what a WORLD of a difference....
I couldn't even get a good slip cue going with the battle pack let alone a decent scratch
in all fairness, i know comparing technics to the battle pack tts is like comparing pure diamonds to diahrrea shit but still...save your money, get technics, numarks ttx or vestex pdx series
to kook up your turntables to virtualDJ
do you need that serato scratch box ?
or just a sound card ?
because i have the hercules RMX console
and could that work as the sound card ?
Yes, you have 2 stereo inputs so you can use Timecode cd or Vinyl.
Ist this a bpm counter on the first tt?
Is this just working if you conekct it with usb or also with normal vinyl?
I think it works with ordinary vinyl but Simon will tell ;)
I have 2 memorex usb turntables, only 1 of them works on virtual dj, i wanna know how to make the other1 work.
it might have been best if you open up a new thread for your current problem instead of digging up an old post. sorry can't help with your problem though.
Hi guys,
I have Technics 1210's and i was wondering if i could connect Virtual DJ up to them via my mac, then, using my own ordinary vinyl, could i use Virtual DJ to beat match these two Vinyl?
Any help would be sweet
Peace
69%
